RCU Forums - View Single Post - Pull-Pull Controls....How?
Old 08-07-2002 | 06:42 PM
KidVermin
Default Pull-Pull Controls....How?
Chris:
You simply use a control horn or rod on top and bottom of the
elevator and each side of the rudder. The standard metal clevis
is used at the end of a threaded connecting rod from the wire.
Your hobby shop will have a pull-pull package by DuBro with detail
instructions for installation. I use 30 lb. plastic coated fishing steel leader then buy the thrd. rod and clevises separately.
Randy
