RCU Forums - View Single Post - TopCap Control Horns
Old 08-07-2002 | 06:28 PM
Billy Hell
Default TopCap Control Horns
So I put all the control horns on for the pull-pull on the ele and rudder. Then I noticed at full throw the ele horn would hit the rudder horn (I didn't even hae the wires hooked up yet and the rudder wires would definitely block the ele from full throw. I bought a Dubro bolt the has the plasic pieces that screw on and act as a horn but they are going to hit the ele too.
What did you guys do to fix this? Should I just not try to get full throw on the down side of the ele? Currently the ele will go all the way down past the fuse (without the problem mentioned above).
