RE: vert stab stability
You are right the vertical fin is weak in side to side. If you look closely you will see the curvature is more on the left side than the right. Hope this was built in to help with right rudder on take off. I used a spruce spar in the vertical fin at the trailing edge with two 1/8" plates to stablize the side to side. Pic attached
