RCU Forums - View Single Post - motor problems
Old 10-03-2004 | 08:24 PM
KidVermin
Default RE: motor problems
Could be two problems.
Does the rpm drop down when you remove the ni-starter ? (Needs a new plug.)
Try opening the main needle 2 turns from close and once you open full throttle (while someone holds the plane) start leaning till you get max rpm, then richen 2 or 3 clicks.
