Smoke is a mess!
good tip : dont get oil inside ur fuz!!!
Check your tank seal??? it may be entering from a leak on your injector ?? Use wing seat tape?? Try to block off all the little holes from behind the exhaust, not only on the side where the smoke exits!
What smoke oil are you using??
