RCU Forums - View Single Post - Capiche 140 EX and IC version
Old 10-04-2004 | 06:09 AM
  #1705
Sprink's Avatar
Sprink
Default RE: Capiche 140
ORIGINAL: Berk
Foof,
1 1/16 Probably wont matter, but you can probably lose that 'teenth when you cover the wing!
It might make the eventual tipstall predicable... It would always go to the right!! though I really don't think tipstall is in this models vocab.
Regards,
Steve
Well I havent managed a tip stall yet, so it beats the C50, even though mine is quite heavy. I have tried to tip stall it, to see how bad it is, and at what point it comes in, but from level flight it just mushes, then goes into an elevator, and vertical dive it either pulls out or does a parachute. There does not seem to be an inbetween . Only trouble is wing rock in harriers.
Foof, I'm quite impressed that you can measure an inaccuracy of that amount, don't think I could. If you are really bothered, carefull use of the iron when covering it could probably eliminate that small amount of difference.
