RE: Rambler-45 second plane? updated
HI ROB
HOPE YOU GOT MY E-MAIL LET ME KNOW . THE ENGINE IS EASY TO MOUNT BUT YOU MUST FIT THE ENGINE
ON THE BEARERS AT THE VERY END THEN OFFER IT UP TO THE FIRE WALL I USED THE EXISTING HOLES
IN THE MOUNT AND FIRE WALL THE AWKWARD BIT IS THE THROTTLE CONTROL ROD IT HAS TO BE
MOVED VERY CLOSE TO THE SIDE WALL USE A BALL AND SOCKET TYPE CONNECTOR ON THE ENGINE
IT WILL GIVE YOU BETTER AJUSTMENT IN FITTING.
