RCU Forums - View Single Post - Skymaster Gripen Almost there
Old 10-05-2004 | 08:37 AM
lov2flyrc's Avatar
lov2flyrc
My Feedback: (24)
Default RE: Skymaster Gripen Almost there
Thanks guys.... Been a bit of a rush job.
Woj--- Thought about eliminating the intake but.... There where two reasons for me keeping it. First, since I am doing an evaluation of the plane for skymaster/airpac I decided it would be best to put everything in as supplied, second.... Some had reported it was difficult to find room for everything. Although the Gripen is not quite as "Roomy" as the rest of the Skymaster line, I did not have any trouble finding a spot for all the required components.
Dan--- Got two things going on here with "Carbon" First, since I plan to be a bit rough on the plane through the evaluation phase the gear mounts have been laminated with 3mm carbon plate. Probably something I would have done regardless. I'm usually overkill in these areas.
The radio tray, air gauge/fill valve tray and rear duct support seen in the pictures are made from Faux carbon ABS laminate. This is a plastic I sell on Dreamworks that has the appearance of carbon without the expense or weight. It is approx 1/16" thick, weight gain is negligible. Provides a nice finish and is very easy to work with.
Todd
