RCU Forums - View Single Post - top hinged ailerons, torque problems solved.
Old 10-05-2004 | 12:30 PM
Cactus.'s Avatar
Cactus.
Default RE: top hinged ailerons, torque problems solved.
you can, but if i didn't have a glass skin in a low stress surface the rod would come out of the top.
and to be on the hinge line half the torque rod would be above the wing surface.
the simple answer is keep the torque rod on the center line where the most meat is and don't hard glue the peg.
