RCU Forums - View Single Post - ThunderTiger Rare Bear
Old 10-05-2004 | 06:50 PM
  #457
Vampire
Default RE: ThunderTiger Rare Bear
Dave G,
This airplane does not need flaps. I have landed it on grass withonly a 30 ft. ground roll. The wing area is approx. 770 sq. in. +/- and at a final weight of 11# the loading is 32.8 oz./ sq/ft. which is excellent.
cstevec, attached are the pic's I have promissed on the OS-1.60 FX remote needle install into the right fuselage exhaust opening. Works just fine. What you do not see in the attached pic's is I put a T into the fuel supply line just ahead of the filter and ran it to the bottom of the firewall with a plug in it. To fuel, I remove the plug, insert the fueling line and pinch off the tubing from the needle to the carb thru the right fuselage exhasut opening. You could of course install the 3rd tube to the fuel tank for fueling.
BR
ID:	179878   Click image for larger version
