RCU Forums - View Single Post - Weed Eater 18cc
Thread: Weed Eater 18cc
Old 10-05-2004 | 07:38 PM
av8tor1977's Avatar
av8tor1977
Default RE: Weed Eater 18cc
Hi,
The plane had the basic dimensions as a Big Stick. It was based on a Big Stick that I crashed years ago, and rebuilt as a Big Low Stick. It is the same plane that is in my "logo picture". Now keep in mind a few things. One, the engine I used was a Kioritz/Echo, which is a higher end engine that would have more power than the cheaper Featherlite 18cc engines to begin with. Two, I was flying at sea level at the time. Density altitude is an important factor in the power of engines. For example, at my present field altitude of 4200' and an average temp of 80+ degrees, the density altitude is over 7000' and the power is down by around 20%. Three, the engine wasn't exactly stock. I raised the compression slightly, added a larger carb, and a very free breathing exhaust along with CH ignition. Lastly, I was happy with the performance of the plane at sea level, but happiness is relative. I wasn't looking for the modern "3D" performance. If it would loop, roll, and pull vertical long enough to make a nice stall turn or tail slide, and bank tight turns without losing too much airspeed, I was happy. The 16cc Kioritz on a 9.5 lbs. plane did this at sea level for me, and I really enjoyed it.
Good luck and take care,
AV8TOR
