RE: 28% edge pics
Anywhere that I was going to put the monokote, I made a pattern and cut away the Ultracote to about a 1/4" less than the actual size to allow for over lapping. So the monokote only really over laps the ultracote by a 1/4". With the exception of the 1/2" charcoal stripe, that is layed right over the ultracote with no problems.
On the cowl, I masked off the section to paint and then sanded it with 400 and 600 wet sand. Painted the two different colors, removed the mask and then wet sanded the entire thing with 600 including the white. Washed it and then applied a couple of coats of Lusterkote crystal clear over the entire cowl.
