Litespan
I have used Litespan on several occasions over two years now.
You guys must be using material different than I got from Peck's Polymers. I got mixed results.
Either it attachs or it will not. The aluminum colored is the worse.
Either it shrinks or it will not. The pale colors (while, yellow, antique) sucked up the best, whereas the darker colors shrink the minimum.
The Balsarite can sometimes ball up when ironing, whereas using Elmer's Glue stick it does not. The distributor from New Jersey reccomends two applications of glue also.
Wm.
