ORIGINAL: basmntdweller
You can do that mix if your radio has programmable mixes. I do the same thing on my Slinger wing so that when I back off the throttle the elevator is at the right trim for power off glide. I doubt it would take much at all to correct it. Start about 2% down at full throttle. Matt
That's what I was thinking, the plane is trimmed for glide, just need the power on elevator mix. He is using a Hitec Eclipse, should be able to program a P-mix or use a flight mode switch. I'll be getting a Filip for myself and I'm watching his closely to ease my setup.
Bill
