RE: FOAM TIRES NTC3!!!
[quote]ORIGINAL: ZipZap
To answer your original question, yes, 30mm rears (0 deg offset) and 26mm fronts are the correct sizes for 200mm nitro. If you're running a 200mm body, and it's mounted correctly, then the tires should not rub.
Mr.ZipZap....I didn't mention where the tires were rubbing, The body sits fine. The Jaco's were rubbing on the inside against the hub carrier. When I tried the Ellegi's there was more space so they didn't rub. Both were 0 deg offset. I like the ellegi's but I also heard good things about the Jaco's. How much difference in the handling if I tried the smallest offset in the Jaco's Thanks for answering, Scotty
P.S. I think I will try the same shore in the front and rear,as I was told by LHS, to get a higher number for the front
