I am looking at possibly buying on of the new 4ch Hobbico SuperStar EP w/Ailerons the new one not the original 3ch.
Here is a link to it..I just want to know if any thing that comes with it will need to be changed in order to have a Lipo battery system. Thanks for any hlep and direction you can send me.
http://www2.towerhobbies.com/cgi-bin...?&I=LXGVZ3&P=0
FEATURES: Construction: Balsa and plywood
Covering: Precovered in a durable plastic film.
Building Time: Ready to fly in just 3-5 hours.
Radio Compartment: Plywood reinforced, allows for easy installation
of standard-sized onboard electronics
Wing: One piece with ailerons and metal joiner rod
Airfoil: Flat-bottom airfoil supplies excellent lift at slow speeds
and also helps keep the model level
Landing Gear: Two piece pre-bent wire 0.098" (2.5mm) in diameter
Wheels: Two 1-3/4" (45mm) diameter foam construction
Propeller: 9x5.5, composite construction
Speed Control: Electronic, with metal heat sink, BEC (battery
eliminator circuitry) and Kyosho type connector, motor limit rating
and other specs not supplied
Motor: Electrifly T-601 preinstalled with leads
Battery: 7-cell 8.4V 2100 mAh
Warranty: Ninety day limited
