RCU Forums - View Single Post - Doesn't look like it can be converted
Old 10-07-2004 | 03:01 AM
torp's Avatar
torp
Default RE: Doesn't look like it can be converted
Hi all + Willdo,
have a distance of 7 7/16" from fire wall to back of prop hub to work too.
Has any one made a mount for this model poulan?
see pic.
Would a 4 tube set up bolted through existing crankcase holes to an alloy back plate and then fixed to a GPMG2000
isolation mount which is in turn bolted to the fire wall work OK ???
Have looked at modifing stock muffler.Std exhaust area 196mm2.
Block up factory holes , rip out internals and put one 16mm id or two 11mm id pipes
onto side or top of muffler.Same area as stock.
Work you think ???
cheers torp.[8D]
ID:	180439   Click image for larger version
