RCU Forums - View Single Post - lusterkote problem
Old 10-07-2004 | 07:35 AM
Campy's Avatar
Campy
Default RE: lusterkote problem
Have you ever considered using latex ? I use latex on almost all of the painted areas on my planes. After the latex "cures" (7 - 10 days average cure time ) I clear coat it with 2 coats of water base polyurethane to make it fuel resistant.
A couple of pluses to the latex:
It can be color matched (except for metalics ) if you bring a sample of the color in.
Cost runs ABOUT $10.00 per QUART
No fumes
If you screw up the painting, it is easily removed (within 12 hours anyway ) with a wet cloth.
Goes on AND adheres well over almost everything.
Soap and water clean up.
