RE: Spring Air / UP2 valve problems - help!
I can't leave the down side open to vent or use plain restrictors, it must be connected through the UP sequencing valve to time the gear and doors. Anyway, the UP provides a restrictor to the down line and it is the restriction that seems to be the cause of the leak, when there is only a tiny pressure difference between both sides, both at high pressure, they seem to be capable of compressing the O ring off the cylinder wall.
H.
