RE: Spring Air / UP2 valve problems - help!
Harry : I use #2 valve with my F-100 and I don't think you can use one with spring down gear. The control piston waits until the gear pressure quits rising and then shifts to the doors. With the down gear lines plugged the door control would be confused.
Darryl Usher
