RE: Spring Air / UP2 valve problems - help!
I've used Spring air gear with sequenced gear doors with no problems.
I used the UP-5 Spring air control valve for the gear and a JMP / Rhom air valve for the gear doors and worked both valves through an electronic sequencer.
I have not had any issues with air leaks, except for the fill valve.
