RCU Forums - View Single Post - Dubro Heavy Duty Pull Pull Question/Help
Old 10-08-2004 | 08:43 AM
ez2bgman's Avatar
ez2bgman
Default Dubro Heavy Duty Pull Pull Question/Help
Hello Eveyone,
I have a few questions: I am building an H9 Aresti 40 and am converting the standard rudder system to Dubro's Heavy Duty Pull Pull system. First, how can you get the wire to pass through the crimps 3 times as the picture shows on the package? Second, the heat shrink that came in the package is way too big, is it necessary to have the heat shrink on, or is more for cosmetics? Third, should the servo arm be the same length as the control horns on the rudder? This is my first attempt at a pull pull setup. Any advice would be greatly appreciated. Thanks.
Gary
