RE: Finally!! 8U/9C synthetic module due out..
The problem is not with the Futaba module becasue I'm sure that it will work with all of the Futaba products as it is designed to do. The problem is that mixing and matching products, though it a lot of cases, will work fine, but to say that it is a Futaba problem because it might not work with an FMA or Berg reciever when a Hitech synth module is put in a Futaba transmitter is just spreading major mis-information. And I'm with WilsonFlyer you mix and match different manufacutures transmitters and recievers and expect them to work perfectly when they have not been tested and certified to work together then you are playing with fire. And it they don't work don't blame the manufacturer.
