RCU Forums - View Single Post - Servo Problem
Thread: Servo Problem
Old 08-10-2002 | 01:39 AM
J Welch
Default Servo Problem
Yes digital servos "sing". Unlike there analog (standard) counterparts. AS far as the play you are experiencing, 2mm worth of play is excessive. Understand that the play in your servo for your tail rotor control should not be no more than your other servos. Tail rotor servos are built for high speed and the gear ratio for reduction from the motor may "appear" sloppier than with other servos when in fact they are not.
