RE: E-Flight Ultimate
I do not change one other thing except I mount the servo for the rudder and elevator sideways through the fuse like many have so the servo arms won't hit. This gives more throw. I put on 3D Foamy's carbon biplane landing gear as it is the best made and 1000 times stronger than the junk that comes with the kit.
My CG came out exactly where the manual says at 95mm. This is ideal as you can swap out packs of various sizes and the CG never moves since the pack is mounted at the top of the cabane strut and the center of the strut is the CG. Ideal.
Norman Ross
[img][/img]
