RCU Forums - View Single Post - GP Shoestring - Does it work with FIRE?
Old 10-10-2004 | 02:34 AM
Per_N's Avatar
Per_N
Default RE: GP Shoestring - Does it work with FIRE?
Hi Harry
I have a Shoestring, and i think a rear exhaust would be almost impossible. The fuselage is a rib construction and you have to take everything apart and re build it and then cover
everything again. I don't think all that job is worth it.
BTW I use i ASP 61 2-stroke and i think that is to small. This plane should have some speed. A four stroke 100 do the work better.
