RE: E-Flight Ultimate
Guys, l'm building the Ultimate to, Do you use the stock servo arms(the longest that comes w/servo) on the hitec55, they don't look like there long enough, when you put the tape on the servo and slide it through the fuse, last hole on tha s/arm is just cleared the fuse side, or you dont worry about this? Apprecite the help Will
spec: himax4100 on stock gearbox
cc25
apache li-poly 11-1v 1200mA
should ought to do the trick.
p/s my first 3-d foamy
