RCU Forums - View Single Post - Calling all small engine Guru's- Ryobi help needed
Old 10-10-2004 | 01:15 PM
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: Calling all small engine Guru's- Ryobi help needed
7900 rpm is very high for a Ryobi with a 18-8 prop. It would take a lot of modification for one to ever achieve that. A stock Ryobi turns a 18-8 about 6900 rpm.
Some Ryobi's had a coil with a rpm limiter in it that wouldn't let the engine run well beyond 7000.
Normally, the biggest effective carb venturi size for this engine would be 7/16" . The Standard carb from the factory is 5/16".
Just thinking
Jim
