I have a kit built Uproar using this same engine. More than enough power and with the throws dialed way up the roll rate is sick. I am using Hitec HS225 servos for everything but the throttle.
Very fun plane. I built this kit
specifically for the .32SX and I believe it is a perfect match.
ORIGINAL: Ernie Misner
I have on OS .32 SX that is looking for a home. I am considering building a light verson of the Uproar or Dazzler, with light battery, servos, etc.
Does anyone have any info to share on either of those two planes? The Uproar is considerably cheaper and they have a $20 gift certificate offer on that plane at Tower right now. I'd go with the Dazzler though, if it were a much better plane. I'ts too bad that neither have real monocote covering, so that is not an issue between the two planes.
Thanks for any info!
Ernie
