ORIGINAL: rcfury
Well.. I had to do it. I just went ahead and bought the VF edge 540. At 12:30 am!! Im in a little mix up between OS and Saito. Might go saito and do it right the first time.
Question about the belly pans. Are they that much of a pain as everyone says? Tips - Tricks?
my $0.02 for you:
1. go with the Saito, you wont be sorry, the toque is to die for!! If its the 66" version get at a Saito 100 at minimum. In a perfect world id be flying one with a YS 1.10. .91 will be sufficient but not for my taste.
2. My belly pan on the Extra wasnt a real pain, I trimmed it out to fit and glued the jebus out of it to the wing. Once on it never came loose.
good luck
matt
