ORIGINAL: Hal deBolt
Hi ya'll,
I am quite ashamed of the manner required to reply to Bill's input.
very embrassing?
I have endeavored to correct the problem to no avail.
I am with Juno internnet service and the problem is that when writing
a reply, after about 5 minutes I am cut off the web and told to restart
if desired.
Would be greatly appreciated if anyone knows a cure for this, if so
could you tell me via Email? Many thanks!
Best wishes,
Hal
[email protected]
Hal-
A sure and simple cure to the problem you are having with losing the connection before you are done composing is to do it offline. Use Notepad or Wordpad, for example, to write your reply, then go online and Copy and Paste it into the Reply to Message box.
Abel
