RCU Forums - View Single Post - Effects of lower nitro on 91FX
Old 10-11-2004 | 01:47 PM
Bax
Default RE: Effects of lower nitro on 91FX
Wtih a ringed engine, and using fuels with 15% or less nitro, you can pretty much run whatevery you want whenever. You'll have to reset the carb a bit to accomodate the fuel change, but not much else. As long as you have enough oil in the fuel, you'll be OK.
If you make a large change, such as from 10% nitro to 30% nitro, then you'll have to do a bit of breakin, because the engine will run a lot hotter and the parts fit will alter drastically at the hotter temps.
