RCU Forums - View Single Post - Uproar OR Dazzler?
Old 10-11-2004 | 04:14 PM
Fubar-One's Avatar
Fubar-One
Default RE: Uproar OR Dazzler?
I mean you hear it go WAWAWAWAWAWA! as it rolls, the rate is so fast. You really want to cover it with VERY contrasting top and bottom colors on the wings. Flew it today (just had to after posting about it last night) and had a real blast with it. I swapped out the 10/5 APC for a 10/4 APC I had and got closer to hovering it. Really needs more rudder.
I would have to open up the hatch and check but I am pretty sure I used a standard sized (600mAh?) rx battery. I have no idea what it weighs as I dont have a scale. Also dont remember where I stuck that battery.
If I were to build another one (I surely will if I destroy it beyond repair) I would mount the engine on a slant or sideways so that the muffler was under the fuse. Top of the wing and tail group gets REAL slimey. Picture here. The underside of the wing and stab is black Ultracote. Pretty easy to tell top from bottom during those insane rolls.
ORIGINAL: Ernie Misner
Fubar, by "sick" roll rate, I think you mean it REALLY rolls!...., right? What battery pack did you go with using the .32, what'd you do to get it to balance right if anything, and how much did she weight, if you remember???
Interesting that the two are basically the same plane. The Uproar seems to come out lighter which would be good for the small engines.
Thanks guys!
Ernie
