re: SIG CAP 231EX Thrust angle
Otter,
To make sure I understand you correctly, you added 0.080" (a bit more than 1/16" thick) spacers at the firewall, under the motor mounts on the left side to increase the right thrust. And you left the down/up thrust alone, with whatever angle the firewall is set at.
Do I have it right?
