RE: starter question
Sounds like your starter cup is too big . Pull the rubber cup out of the metal housing and flip it over. Most of the rubber cups have a hole in the back to clear the bolt that holds the cup housing to the starter motor shaft. It may fit as is or you can wallow it out with a pocket knife. Then flip it back around as needed for the bigger spinner. Put it in backwards for the smaller spinner.
