RE: HELP - 8103 Trims went crazy on their own
Finally duplicated the problem...
No problem with the interference...It's a Tx issue
Happens on different models, not just the Yak
I did reset and try on a new model memory...
So here is what I found,
ONLY when the aileron stick is pushed to the left and the elevator trim is moved down, both the aileron & rudder trim move all the way to the right as if they were slaved to the elevator trim...
Very weird...
Doesn't happen with any other combination.
Radio is on it's way to horizon tomorrow.
