RCU Forums - View Single Post - Evolution TPS .46
Old 10-12-2004 | 11:34 PM
phread59
Default RE: Evolution TPS .46
Us some blue loctite on the screws to keep the muffler together. As others have said your low speed needle sounds off. You actually run on the low needle untill around 3/3rds throttle. The low needle adjustment is critical. I also agree, ditch the 10-6, too small. Start with an 11-6 and go from there. Good luck with it. A Fox or an OS plug should help. I have read where these engines sometimes have a taste for an idle bar plug. Try one and see how it works. I have used Fox's for years and always had good service from them.
Mark Shuman
