RCU Forums - View Single Post - Improve (inverted) flight performance by 'trimming' both ailerons up?
Old 10-13-2004 | 07:57 AM
John Murdoch's Avatar
John Murdoch
Default RE: Improve (inverted) flight performance by 'trimming' both ailerons up?
Okay.. Now I've got a question for you guys. For those of you that say you need to just breathe on the stick for inverted flight, do you do that with your elevator expo set or with zero expo? My point here is most people set their expo in the 30% or so range for a softer neutral. If you were to have zero expo, that would be a slight breath. If you put in expo, then, maybe a little breeze on the stick. And if you use a lot of expo, you may need a tornado blowing on the stick. Get my point? Some radios give you the ability to set up/down expo at different rates. Couldn't you set the up expo rate differently that would give you the results you want?
