RCU Forums - View Single Post - Vectorflight: Take a look!
Old 10-13-2004 | 11:40 AM
  #72
Primodus's Avatar
Primodus
My Feedback: (56)
Default RE: Vectorflight: To good to be true?
Installed the tail struts this morning on the top side only. (Should I put some on bottom also?) I used 2-56 metal pushrods, custom fitted and bolted thru both the horzontal and vertical stabs with 6-32/1" bolts. The tail needed the extra weight anyway to help move the CG in line. They are pretty stiff in both directions of flex so I opted not to add them to the bottom side at this time.
