RE: Pipe Tuning
You have the pipe a bit too short. Lengthen it about 1/2 inch and try it. The needle should be more stable. Anytime you have trouble needling a healthy engine with a tuned pipe it means your pipe is too short or your prop is too big. If you can't lengthen your pipe at least 1/2 inch try an 8x7 prop instead.
