RCU Forums - View Single Post - Modify four-star 40
Old 10-13-2004 | 04:04 PM
britbrat
Default RE: Modify four-star 40
If you put a reverse taper on the rudder when you add material (make the bottom wider than the top) it should reduce the pitch-to-belly trim change with rudder input.
