RCU Forums - View Single Post - Modify four-star 40
Old 10-13-2004 | 04:40 PM
mpalermo
Default RE: Modify four-star 40
ORIGINAL: britbrat
If you put a reverse taper on the rudder when you add material (make the bottom wider than the top) it should reduce the pitch-to-belly trim change with rudder input.
Cool... did not know that.. how much are you talking about? would it be a gradual taper through the whole rudder, Top to Bottom? Or just a mass of material at the bottom?
Mike
