Also, I ignored the directions on setting the control throws.
While this may have worked for you, as a general rule it's a bad idea. This being the beginner's forum, you shouldn't ignore any directions that came with the plane unless there have been corrections issued by the manufacturer. Always fly any plane for the first time with the recommended throws. If your radio has duel rates, set them up so you have the option to switch to higher rates but fly on low to start out. You can always add more throw after the first flights if you feel it is necessary but having too much for the initial flight can be fatal.
