RCU Forums - View Single Post - clunk won't fall forward?
Old 10-13-2004 | 11:56 PM
kokamo's Avatar
kokamo
Default RE: clunk won't fall forward?
if you think about it, when somthing is falling at it's terminal velocity,(at its own pace with no engine power) it will have 0 g's, so will everything inside the plane. if you were going strait up, the fuel will beat the back of the tank. When you stall the plane, you then have 0 g's as long as the plane is falling at it's own fall rate (no engine power) the fuel is kinda floating around in the tank, along with the klunk. Most of it will be at the back of the tank, where it was when you were going verticle. Even if you have engine power, going verticly down, you then have a certain amount of g's that will make the fuel stay at the back of the tank. At most times you have a pull from the engine that makes the fuel go to the rear of the tank, like you fall back into the seat when you accellerate fast in a full size car All and all, you more than likely will not have any problems.........please read my feedback to Rubberduck.
MR. Rubberduck, I had that same problem with a trainer, the klunk always got stuck, regardless of a rough landing. What it was was the really junk, trashy, no good fer nothing, crappy ole fuel line they sometimes include with a tank. I used it and had your same problem. I found that if you set-up the klunk like you would any other way with fresh $1.50 per foot pink fuel line, (red, green, blue, yellow, orange, or purple WILL NOT WORK...........girlfreind was with me when I purchased fuel line ) it will work like it should and won't get stuck kinked over and at the top of the tank like yours. Sorry I got sidetracked. ANYWAYS, HOPE THIS HELPS!!!!
P.S. Rubberduck......if you have problems......don't kick yer plane.......give it to me!!!
Joe
