RCU Forums - View Single Post - MVVS Q500
Thread: MVVS Q500
Old 10-14-2004 | 07:32 AM
  #47
DarZeelon's Avatar
DarZeelon
Default RE: MVVS Q500
Vulpina,
To perform the best break-in, follow this [link=http://www.rcuniverse.com/forum/m_1850473/anchors_1850473/mpage_1/key_break%252Din%252Ctapered%252Dbore/anchor/tm.htm#1850473]break-in thread[/link]. It is much better explained than in the MVVS manual.
You must be able to determine by sound, if a two-stroke engine is operating in two-cycle mode, or in four-cycle mode.
Although you live in France and better quality synthetic oils are available to you (Motul Micro, Sachs Aerosynth II/Aerosave), the break-in is best done with degummed Castor oil.
MVVS actually tells you to use only Castor (Ricin) oil, for all their engines.
I would recommend using a 9x6, or an 8x8 prop for break-in.
The 9x7 offers more load, so it isn't as good for this purpose.
