RE: Ryobi 31cc safe temp??
Hi,
The gas engines are not nearly as critical about lean running as the glow engines, and do not like to be run real rich. You don't want to hear a reassuring occasional rich burble like is ok on a glow engine. It usually works best to adjust for peak rpms, and then just open the needle 1/8 turn or less. If you adjust it too rich, it will eventually carbon up, freeze the rings in their grooves and seize. You will sometimes notice a kind of a burble if/when the engine unloads in a dive; this is normal.
Have fun,
AV8TOR
