A hairline crack.... as in, the carburetor hit something and broke out the engine? Or as in, there's a gap at the O-ring mounting?
If there's been a mechanical leverage on that carb, to open a crack in the block, I think you'll have some deformation inside. Some engines need a tight clearance for the crankshaft to spin in, under the carb.
If it's just a casting flaw or an undersize O-ring, all you need is some Hi-Temp Silicone Sealer. If it's a deformed crankcase, you might want to run it on a test stand after you fix it, for a few tanks, to make sure there's no interference. Or, to make the flaw exhibit itself.
Good luck,
Dave Olson
ORIGINAL: BillS
CA and heat
I am considering using CA or maybe epoxy to patch a hairline crack in an engine. The hairline is at the carburetor barrel mounting.
Has anyone had experience with CA and hairline cracks in locations that get hot? What were the results? Ay advice?
