RE: Ryobi 31cc safe temp??
This is true, but you have to get close first. You also have to run the engine for a few minutes at full throttle, then shut it off without letting it idle. Then the plug insulator will be tan to chocolate brown if the mixture is right, and the outer shell will be black with no increasing deposits.
AV8TOR
