RCU Forums - View Single Post - Thrust vector: Single engine vs Multiple
Old 10-14-2004 | 06:47 PM
kram's Avatar
kram
My Feedback: (7)
Default Thrust vector: Single engine vs Multiple
I hate to pose a question that so nakedly exposes my ignorance of aerodynamic basics, but we have a problem with a B-17:
On a single engine plane with wing and stabilizer incidence set at 0 degrees, putting 2 degree down incidence on the engine will cause the whole plane to go down, correct?
On a similar plane with multiple engines (wing-mounted), what happens if the engines are given a down incidence of 2 degrees?
Will the plane still go down?
Or does the engine thrust line force the wing and stab into relative 2 degree positive position in flight and cause the plane to go up?
Or does it depend on the plane? B-17?
Thank You
mt
