It depends on what you want....
The FAI pylon guys like to go as fast as possible, so they run a big venturi without a throttle. If you want to run as fast as possible, then this would be what you would want.
If you want to be able to control the RPMs via a throttle, you will have to make a few compromises. The Q500 carb uses a venturi diameter which allows for fuel draw at settings other than full throttle..
